Pomoč pri arduino kodi za robotsko roko
igi82m
Pridružen-a: Pon 09 Avg 2021 18:14
Prispevkov: 5
Aktiv.: 0.11
PrispevekObjavljeno: Pon Avg 09, 2021 7:04 pm    Naslov sporočila:  Pomoč pri arduino kodi za robotsko roko Odgovori s citatom
Pozdravljeni , ker sem bolj začetnik v tem ,bi rabil pomoč pri arduino kodi za robotsko roko z uporabo joystika in shranjevanje pozicije. Spletna stran z kodo katero uporabljam.
MeArm Robot
Težava je v tem , da jaz uporabljam 3 joystike in 6 servotov , koda pa je za 2 joystika in 4 servote. Kodo sem kolikor sem znal spremenil tako , da zadeva z joystiki in servoti ročno deluje. Zdaj je težava v shranjevanju pozicij , v serial monitorju mi pokaže 6 vrstic za vsak servo in tudi pokaže vrednosti ko premikam joystik tako kot mora. Problem je , da mi pozicijo dveh dodanih servotov ne shrani na pravo vrstico , oziroma shranjuje dvakrat na isto mesto. Kaj bi moral dodat oziroma spremenit v kodi?
Hvala.
Koda:
   meArm analog joysticks version 1.5.4 - UtilStudio.com Dec 2018
   Uses two analogue joysticks and four servos.
   In version 1.5.4 was replaced an external resistors by internal pull up resistors.
   External LED diode was replaced with using internal "L" diode on Arduino UNO board.
   Some bugs was removed.
   First joystick moves gripper forwards, backwards, left and right,
   button start/stop recording positions.
   Second joystick moves gripper up, down, and closes and opens,
   button start/stop playing recorded positions.
   Press button for 2 seconds to autoplay.
   Pins:
   Arduino    Stick1    Stick2    Base   Shoulder  Elbow    Gripper   Record/
      GND       GND       GND    Brown     Brown   Brown     Brown    Auto play
       5V       VCC       VCC      Red       Red     Red       Red    LED
       A0       HOR
       A1       VER
       PD2      BUTT
       A2                 HOR
       A3                 VER
       PD3                BUTT
       11                       Yellow
       10                                 Yellow
        9                                         Yellow
        6                                                   Yellow
       13                                                             X
bool repeatePlaying = false; /* Repeatedly is running recorded cycle */
int delayBetweenCycles = 2000; /* Delay between cycles */
int basePin = 11;       /* Base servo */
int shoulderPin = 10;   /* Shoulder servo */
int elbowPin = 9;       /* Elbow servo */
int gripperPin = 6;     /* Gripper servo */
int forearmPin = 5;        /* ForeArm servo */
int wristPin = 4;          /* Wrist servo*/
int xdirPin = 0;        /* Base - joystick1*/
int ydirPin = 1;        /* Shoulder - joystick1 */
int zdirPin = 3;        /* Elbow - joystick2 */
int gdirPin = 2;        /* Gripper - joystick2 */
int sdirPin = 4;        /* ForeArm - joystick3 */
int rdirPin = 5;        /* Wrist - joystick3 */
//int pinRecord = A4;     /* Button record - backward compatibility */
//int pinPlay = A5;       /* Button play  - backward compatibility */
int pinRecord = PD2;     /* Button record - recommended (A4 is deprecated, will by used for additional joystick) */
int pinPlay = PD3;       /* Button play  - recommended (A5 is deprecated, will by used for additional joystick) */
int pinLedRecord = 13;   /* LED - indicates recording (light) or auto play mode (blink ones) */
const int buffSize = 512; /* Size of recording buffer */
int startBase = 135;
int startShoulder = 95;
int startElbow = 90;
int startGripper = 0;
int startForeArm = 155;
int startWrist = 150;
int posBase = 90;
int posShoulder = 90;
int posElbow = 90;
int posGripper = 0;
int posForeArm = 90;
int posWrist = 90;
int lastBase = 90;
int lastShoulder = 90;
int lastElbow = 90;
int lastGripper = 0;
int lastForeArm = 90;
int lastWrist = 90;
int minBase = 10;
int maxBase = 150;
int minShoulder = 10;
int maxShoulder = 150;
int minElbow = 0;
int maxElbow = 180;
int minGripper = 100;
int maxGripper = 150;
int minForeArm = 0;
int maxForeArm = 180;
int minWrist = 0;
int maxWrist = 180;
const int countServo = 6;
int buff[buffSize];
int buffAdd[countServo];
int recPos = 0;
int playPos = 0;
int buttonRecord = HIGH;
int buttonPlay = HIGH;
int buttonRecordLast = LOW;
int buttonPlayLast = LOW;
bool record = false;
bool play = false;
bool debug = false;
String command = "Manual";
int printPos = 0;
int buttonPlayDelay = 20;
int buttonPlayCount = 0;
bool ledLight = false;
Servo servoBase;
Servo servoShoulder;
Servo servoElbow;
Servo servoGripper;
Servo servoForeArm;
Servo servoWrist;
void setup() {
  Serial.begin(9600);
  pinMode(xdirPin, INPUT);
  pinMode(ydirPin, INPUT);
  pinMode(zdirPin, INPUT);
  pinMode(gdirPin, INPUT);
  pinMode(sdirPin, INPUT);
  pinMode(rdirPin, INPUT);
  pinMode(pinRecord, INPUT_PULLUP);
  pinMode(pinPlay, INPUT_PULLUP);
  pinMode(pinLedRecord, OUTPUT);
  servoBase.attach(basePin);
  servoShoulder.attach(shoulderPin);
  servoElbow.attach(elbowPin);
  servoGripper.attach(gripperPin);
  servoForeArm.attach(forearmPin);
  servoWrist.attach(wristPin);
  StartPosition();
  digitalWrite(pinLedRecord, HIGH);
  delay(1000);
  digitalWrite(pinLedRecord, LOW);
void loop() {
  buttonRecord = digitalRead(pinRecord);
  buttonPlay = digitalRead(pinPlay);
  //  Serial.print(buttonRecord);
  //  Serial.print("\t");
  //  Serial.println(buttonPlay);
  //  for testing purposes
  if (buttonPlay == LOW)
    buttonPlayCount++;
    if (buttonPlayCount >= buttonPlayDelay)
      repeatePlaying = true;
  else buttonPlayCount = 0;
  if (buttonPlay != buttonPlayLast)
    if (record)
      record = false;
      play = !play;
      if (play)
        StartPosition();
  if (buttonRecord != buttonRecordLast)
    if (buttonRecord == LOW)
      record = !record;
      if (record)
        play = false;
        recPos = 0;
      else
        if (debug) PrintBuffer();
  buttonPlayLast = buttonPlay;
  buttonRecordLast = buttonRecord;
  float dx = map(analogRead(xdirPin), 0, 1023, -5.0, 5.0);
  float dy = map(analogRead(ydirPin), 0, 1023, -5.0, 5.0);
  float dz = map(analogRead(zdirPin), 0, 1023, 5.0, -5.0);
  float dg = map(analogRead(gdirPin), 0, 1023, 5.0, -5.0);
  float ds = map(analogRead(sdirPin), 0, 1023, -5.0, 5.0);
  float dr = map(analogRead(rdirPin), 0, 1023, -5.0, 5.0);
  if (abs(dx) < 1.5) dx = 0;
  if (abs(dy) < 1.5) dy = 0;
  if (abs(dz) < 1.5) dz = 0;
  if (abs(dg) < 1.5) dg = 0;
  if (abs(ds) < 1.5) ds = 0;
  if (abs(dr) < 1.5) dr = 0;
  posBase += dx;
  posShoulder += dy;
  posElbow += dz;
  posGripper += dg;
  posForeArm += ds;
  posWrist += dr;
  if (play)
    if (playPos >= recPos) {
      playPos = 0;
      if (repeatePlaying)
        delay(delayBetweenCycles);
        StartPosition();
      else
        play = false;
    bool endOfData = false;
    while (!endOfData)
      if (playPos >= buffSize - 1) break;
      if (playPos >= recPos) break;
      int data = buff[playPos];
      int angle = data & 0xFFF;
      int servoNumber = data & 0x5000;
      endOfData = data & 0x6000;
      switch (servoNumber)
        case 0x0000:
          posBase = angle;
          break;
        case 0x1000:
          posShoulder = angle;
          break;
        case 0x2000:
          posElbow = angle;
          break;
        case 0x3000:
          posGripper = angle;
           break;
        case 0x4000:
          posForeArm = angle;
          break;
        case 0x5000:
          posWrist = angle;
          ds = posWrist - lastWrist;
          break;
      playPos++;
  if (posBase > maxBase) posBase = maxBase;
  if (posShoulder > maxShoulder) posShoulder = maxShoulder;
  if (posElbow > maxElbow) posElbow = maxElbow;
  if (posGripper > maxGripper) posGripper = maxGripper;
  if (posForeArm > maxForeArm) posForeArm = maxForeArm;
  if (posWrist > maxWrist) posWrist = maxWrist;
  if (posBase < minBase) posBase = minBase;
  if (posShoulder < minShoulder) posShoulder = minShoulder;
  if (posElbow < minElbow) posElbow = minElbow;
  if (posGripper < minGripper) posGripper = minGripper;
  if (posForeArm < minForeArm) posForeArm = minForeArm;
  if (posWrist < minWrist) posWrist = minWrist;
  servoBase.write(posBase);
  servoShoulder.write(posShoulder);
  servoElbow.write(posElbow);
  servoForeArm.write(posForeArm);
  servoWrist.write(posWrist);
  //  if (dg < -3.0) {
  //    posGripper = minGripper;
  //    servoGripper.write(posGripper);
  //    Serial.println(posGripper);
  //  else if (dg > 3.0) {
  //    posGripper = maxGripper;
  bool waitGripper = false;
  if (dg < 0) {
    waitGripper = true;
  else if (dg > 0) {
    waitGripper = true;
  if (play && waitGripper)
    delay(1000);
  //Serial.println(posGripper);
  if ((lastBase != posBase) | (lastShoulder != posShoulder) | (lastElbow != posElbow) | (lastGripper != posGripper) | (lastForeArm != posForeArm) | (lastWrist != posWrist))
    if (record)
      if (recPos < buffSize - countServo)
        int buffPos = 0;
        if (lastBase != posBase)
          buffAdd[buffPos] = posBase;
          buffPos++;
        if (lastShoulder != posShoulder)
          buffAdd[buffPos] = posShoulder | 0x1000;
          buffPos++;
        if (lastElbow != posElbow)
          buffAdd[buffPos] = posElbow | 0x2000;
          buffPos++;
        if (lastGripper != posGripper)
          buffAdd[buffPos] = posGripper | 0x3000;
          buffPos++;
        if (lastForeArm != posForeArm)
          buffAdd[buffPos] = posForeArm | 0x4000;
          buffPos++;
         if (lastWrist != posWrist)
          buffAdd[buffPos] = posWrist | 0x5000;
          buffPos++;
        buffAdd[buffPos - 1] = buffAdd[buffPos - 1] | 0x6000;
        for (int i = 0; i < buffPos; i++)
          buff[recPos + i] = buffAdd[i];
        recPos += buffPos;
    command = "Manual";
    printPos = 0;
    if (play)
      command = "Play";
      printPos = playPos;
    else if (record)
      command = "Record";
      printPos = recPos;
    Serial.print(command);
    Serial.print("\t");
    Serial.print(printPos);
    Serial.print("\t");
    Serial.print(posBase);
    Serial.print("\t");
    Serial.print(posShoulder);
    Serial.print("\t");
    Serial.print(posElbow);
    Serial.print("\t");
    Serial.print(posGripper);
    Serial.print("\t");
    Serial.print(posForeArm);
    Serial.print("\t");
    Serial.print(posWrist);
    Serial.print("\t");
    Serial.print(record);
    Serial.print("\t");
    Serial.print(play);
    Serial.println();
  lastBase = posBase;
  lastShoulder = posShoulder;
  lastElbow = posElbow;
  lastGripper = posGripper;
  lastForeArm = posForeArm;
  lastWrist = posWrist;
  if ( repeatePlaying)
    ledLight = !ledLight;
  else
    if (ledLight)
      ledLight = false;
    if (record)
      ledLight = true;
  digitalWrite(pinLedRecord, ledLight);
  delay(50);
void PrintBuffer()
  for (int i = 0; i < recPos; i++)
    int data = buff[i];
    bool endOfData = data & 0x6000;
    Serial.print("Servo=");
    Serial.print(servoNumber);
    Serial.print("\tAngle=");
    Serial.print(angle);
    Serial.print("\tEnd=");
    Serial.print(endOfData);
    Serial.print("\tData=");
    Serial.print(data, BIN);
    Serial.println();
void StartPosition()
  int angleBase = servoBase.read();
  int angleShoulder = servoShoulder.read();
  int angleElbow = servoElbow.read();
  int angleGripper = servoGripper.read();
  int angleForeArm = servoForeArm.read();
  int angleWrist = servoWrist.read();
  Serial.print(angleBase);
  Serial.print("\t");
  Serial.print(angleShoulder);
  Serial.print("\t");
  Serial.print(angleElbow);
  Serial.print("\t");
  Serial.print(angleGripper);
  Serial.print("\t");
  Serial.print(angleForeArm);
  Serial.print("\t");
  Serial.print(angleWrist);
  Serial.println("\t");
  posBase = startBase;
  posShoulder = startShoulder;
  posElbow = startElbow;
  posGripper = startGripper;
  posForeArm = startForeArm;
  posWrist = startWrist;
airwolf
Prispevkov: 2219
Aktiv.: 10.68
Kraj: Polhov Gradec
PrispevekObjavljeno: Tor Avg 10, 2021 12:58 pm    Naslov sporočila:   Odgovori s citatom
Premajhen buffer?
LP Gašper
igi82m
Prispevkov: 5
Aktiv.: 0.11
PrispevekObjavljeno: Tor Avg 10, 2021 4:02 pm    Naslov sporočila:   Odgovori s citatom
Za koliko ga lahko še povečam?
Prispevkov: 3531
Aktiv.: 31.53
PrispevekObjavljeno: Tor Avg 10, 2021 5:46 pm    Naslov sporočila:   Odgovori s citatom
Poglej, kaj izpiše prevajalnik na koncu za RAM.
igi82m
Prispevkov: 5
Aktiv.: 0.11
PrispevekObjavljeno: Tor Avg 10, 2021 6:03 pm    Naslov sporočila:   Odgovori s citatom
Sem ga še malo povečal , na 96%. Pa ne pomaga , še vedno isto. Kaj bi še lahko probal?
mato1111
Prispevkov: 617
Aktiv.: 4.06
Kraj: Vrhnika
PrispevekObjavljeno: Tor Avg 10, 2021 8:40 pm    Naslov sporočila:   Odgovori s citatom
Koda:
Zakaj v tem primeru bitni OR z 0x5000? (ali pa 0x1000, 0x2000, ...)
PS:
Mi je že jasno... neke vrste "koda"ki se zapiše pred vrednost pozicije po kateri program ve kateri sklep je treba premaknit ko bere ven iz buferja...
igi82m
Prispevkov: 5
Aktiv.: 0.11
PrispevekObjavljeno: Sre Avg 11, 2021 7:17 pm    Naslov sporočila:   Odgovori s citatom
Samo , zakaj ne shrani oziroma bere iz pravega?
mato1111
Prispevkov: 617
Aktiv.: 4.06
Kraj: Vrhnika
PrispevekObjavljeno: Sre Avg 11, 2021 9:38 pm    Naslov sporočila:   Odgovori s citatom
igi82m je napisal/a:
Malo preglej program da kje ne bereš/pišeš 2x al pa če po nesreči zapišeš v napačnega.
igi82m
Prispevkov: 5
Aktiv.: 0.11
PrispevekObjavljeno: Pon Avg 16, 2021 6:00 pm    Naslov sporočila:   Odgovori s citatom
Težave se začnejo , ko dodam te vrednosti za dodatna servota (ForeArm 0x4000 in Wrist 0x5000). Takrat se mi shranjevanje vse zameša. V čem je problem?
Moja koda 6xservo 3xJoy
case 0x0000:
posBase = angle;
break;
case 0x1000:
break;
case 0x2000:
posElbow = angle;
break;
case 0x3000:
posGripper = angle;
break;
case 0x4000:
posForeArm = angle;
break;
case 0x5000:
posWrist = angle;
break;
if (record)
int buffPos = 0;
buffPos++;
buffPos++;
buffPos++;
buffPos++;
buffPos++;
buffPos++;
Orginal koda za 4xservo 2xJoy
int servoNumber = data & 0x3000;
endOfData = data & 0x4000;
case 0x0000:
posBase = angle;
break;
case 0x1000:
break;
case 0x2000:
posElbow = angle;
break;
case 0x3000:
posGripper = angle;
ds = posGriper - lastGriper;
break;
if ((lastBase != posBase) | (lastShoulder != posShoulder) | (lastElbow != posElbow) | (lastGripper != posGripper))
if (record)
int buffPos = 0;
buffPos++;
buffPos++;
buffPos++;
buffPos++;
buffAdd[buffPos - 1] = buffAdd[buffPos - 1] | 0x4000;
Prispevkov: 3531
Aktiv.: 31.53
PrispevekObjavljeno: Tor Avg 17, 2021 8:16 am    Naslov sporočila:   Odgovori s citatom
Naslednjič objavi bolj čitljivo kodo in uporabi oblikovanje s [ code ]:
Koda:
int angle = data &0xFFF;
int servoNumber = data &0x5000;
endOfData = data &0x6000;
  case 0x0000:
    posBase = angle;
    break;
  case 0x1000:
    break;
  case 0x2000:
    posElbow = angle;
    break;
  case 0x3000:
    posGripper = angle;
    break;
  case 0x4000:
    posForeArm = angle;
    break;
  case 0x5000:
    posWrist = angle;
    break;
      if (record)
          int buffPos = 0;
            buffPos++;
            buffPos++;
            buffPos++;
            buffPos++;
            buffPos++;
            buffPos++;
Tule imaš ustrezno "orodje":
https://techiedelight.com/tools/clike
Gornje oblikovanje sicer ni najlepše. Predlagam, da si pogledaš še tole:
https://github.com/MaJerle/c-code-style
airwolf
Prispevkov: 2219
Aktiv.: 10.68
Kraj: Polhov Gradec
PrispevekObjavljeno: Tor Avg 17, 2021 8:21 am    Naslov sporočila:   Odgovori s citatom
int servoNumber = data &0x3000;
endOfData = data &0x4000;
Ali nebi slučajno moral biti tale:
takole:
Edit sem videl da je to stara koda (preden si jo predelal za 6 servotov), ignoriraj.
LP Gašper
