Poučna inženirska
Umnik
Prispevkov: 958
Aktiv.: 4.04
Kraj: Novo mesto
PrispevekObjavljeno: Pet Jun 15, 2007 9:14 am    Naslov sporočila:  Poučna inženirska Odgovori s citatom
Problem: One of the most memorable case studies on Japanese management was the case of the empty soap box, which happened in one of Japan's biggest cosmetics companies. The company received a complaint that a consumer had bought a soap box that was empty. Immediately the thorities isolated the problem to the assembly line, which transported all the packaged boxes of soap to the delivery department. For some reason, one soap box went through the assembly line empty. Management asked its engineers to solve the problem. Post-haste,
Solution A: The engineers worked hard to devise an X-ray machine with high-resolution monitors manned by two people to watch all the soap boxes that passed through the line to make sure they were not empty. No doubt, they worked hard and they worked fast but they spent whoopee amount to do so
Solution B: But when a rank-and-file employee in a small company was posed with the same problem, he did not get into complications of X-rays, etc but instead came out with another solution. He bought a strong industrial electric fan and pointed it at the assembly line. He switched the fan on, and as each soap box passed the fan, it simply blew the empty boxes out of the line.
Moral of the story: " Keep It Short & Simple" !! i.e. always look for simple solutions. Devise the simplest possible solution that solves the problem. So, learn to focus on solutions not on problems
Samo v razmislek
mucek4
Prispevkov: 2952
Aktiv.: 12.46
PrispevekObjavljeno: Pet Jun 15, 2007 9:56 am    Naslov sporočila:   Odgovori s citatom
Princip poljuba temu pravijo američani (KISS). Keep it simple, stupid.
trot
Prispevkov: 1282
Aktiv.: 5.72
Kraj: glej fogl
PrispevekObjavljeno: Pet Jun 15, 2007 10:06 am    Naslov sporočila:   Odgovori s citatom
Tako kot tista reklama: "Porabili smo leta in milijone za razvoj kulija, ki lahko piše tudi v vesolju. In kaj je uporabila konkurenca - svinčnik" Laughing
Ne vem a je bil to štos, a je bilo res Cool
Sokrat
Prispevkov: 5584
Aktiv.: 23.56
PrispevekObjavljeno: Pet Jun 15, 2007 10:21 am    Naslov sporočila:   Odgovori s citatom
trot je napisal/a:
http://www.snopes.com/business/genius/spacepen.asp
Aktiv.: 60.04
PrispevekObjavljeno: Pet Jun 15, 2007 11:58 am    Naslov sporočila:   Odgovori s citatom
trot je napisal/a:
Res je bilo ! Navaden svinčnik !
Ampak pri tej zgodbi je zamolčano dejstvo, da je zlomljena grafitna konica "odplavala" in naredila nekaj elektronske zmede v napravah.
Iztok
Prispevkov: 4974
Aktiv.: 20.99
PrispevekObjavljeno: Pet Jun 15, 2007 12:32 pm    Naslov sporočila:   Odgovori s citatom
Pred leti sem imel za rešit podoben problem na liniji za polnjenje plastičnih sveč z voskom. Mehaniki so mi že skoraj izdelali konstrukcijo s fotocelico in drugimi senzorji ter začeli pripravljat kanale in prostor za elektro omarico avtomatike v kateri bo najmanj LOGO! krmilnik ...
Jaz pa sem vzel spiralno vzmet v obliki palčke (za razteg) dolgo cca. 20cm premera 1cm in jo pritrdil na ograjico transportnega traku po katerem so šle sveče, tako da se je kot zapornica ukrivila ob prehodu vsake polne sveče. Če je bila kakšna sveča brez voska (prelahka) jo je vzmet odrinila na stran traku kjer ni bilo ograjice ... Cool ... mehaniki pa Evil or Very Mad ... Laughing
boco
Pridružen-a: Čet 31 Jul 2003 9:42
Prispevkov: 919
Aktiv.: 3.88
Kraj: Ptuj/Kranj/Ljubljana
PrispevekObjavljeno: Pet Jun 15, 2007 12:59 pm    Naslov sporočila:   Odgovori s citatom
Iztok, ....jaz bi še manj kompliciral in bi postavil ventilator, ki bi pač prazno plastiko samo odpihnil iz traku Shocked .
Boco
Iztok
Prispevkov: 4974
Aktiv.: 20.99
PrispevekObjavljeno: Pet Jun 15, 2007 1:20 pm    Naslov sporočila:   Odgovori s citatom
boco je napisal/a:
Boco
No, ne vem kaj je večja komplikacija in neprijetnost za prisotne delavce?
Da nepotrebnega pihanja, hrupa, porabe el. energije, vlečenja novih kablov, ipd. sploh ne omenjam ... Wink
Sergej
Pridružen-a: Tor 29 Avg 2006 19:43
Prispevkov: 280
Aktiv.: 1.22
PrispevekObjavljeno: Pet Jun 15, 2007 1:48 pm    Naslov sporočila:   Odgovori s citatom
Moje videnje:
Američani rinejo z glavo skozi zid, dokler zadeva ne deluje.
Nemci dodelajo do popolnosti, da komaj še deluje.
Rusi tako poenostavijo, da včasih ne deluje več.
Obstaja poseben problem pri razvoju po naročilu. Za problem vreden 100 je obstajala enostavna rešitev, ki bi stala 10. Seveda se je dodalo čuda nekih sistemov, da je na koncu vse skupaj za silo izgledalo vredno recimo 70.
Avtor rešitve vsaj približno ve kolikšen prihranek bo nekaj prineslo in če se le da, zaračuna del bodočega dobička. Vsaka firma bi zato morala predvsem sama razvijat svojo tehnologijo. Za primer je lahko Kolektor, ki se je po tem receptu prebil na prvo mesto v svetu.
