alessio Član
Pridružen-a: Pon 04 Dec 2006 8:39 Prispevkov: 363 Aktiv.: 1.54 Kraj: Ljubljana
Objavljeno: Čet Avg 30, 2007 7:45 am Naslov sporočila: "FGPA design from scratch"-Tutorial |
Hoj,
na spodnjem naslovu se nahaja zanimiva serija na temo FPGA,
(čigar avtor je Sven-Åke Andersson, če komu to kaj pove ).
Tutoriali imajo poudarek na soft procesorjih, konkretno Xilinx-ov (R) MicroBlaze(TM).
FPGA design from scratch
Vsebina serije:
* Part 1 Introduction / let's get started
* Part 2 Defining a design project
* Part 3 Introducing the development environment
* Part 4 Running Xilinx's Integrated Software Environment (ISE)
* Part 5 Setting up the simulation environment
* Part 6 The simulation process using NCSIM
* Part 7 Running a simulation and degugging the design
* Part 8 Using a HDL Analysis and Lint tool (HAL)
* Part 9 Regression testing
* Part 10 Synthesis with timing constraints
* Part 11 The Field Programmable Gate Array (FPGA) description
* Part 12 Adding synthesis constraints
* Part 13 Installing the Embedded Development Kit (EDK) from Xilinx
* Part 14 Software upgrades
* Part 15 Building a system using Xilinx Platform Studio (XPS)
* Part 16 Create or import a user peripheral
* Part 17 Adding our design object and generating a system netlist
* Part 18 Putting together a system simulation environment
* Part 19 Generating a Verilog testbench
* Part 20 Running our first simulation and adding the DDR SDRAM
* Part 21 Debugging IP blocks
* Part 22 Using the XPS Sofware Development Kit (SDK)
* Part 23 Simulating MicroBlaze program execution
* Part 24 More system simulations
* Part 25 Implementing the hardware platform. Generating the bitstream.
* Part 26 Using iMPACT, the configuration tool
* Part 27 The pin assignment closure process
* Part 28 Power calculations using XPower
* Part 29 Hardware and software setup
* Part 30 Running demonstration software applications
* Part 31 Adding a 16x2 character LCD display
* Part 32 Writing the "Hello World" program
* Part 33 Simulating the LCD driver
* Part 34 The MicroBlaze program layout
* Part 35 Using Simgen to generate simulation HDL files
* Part 36 Finishing the LCD driver
* Part 37 Software debugging using Xilinx Microprocessor Debugger (XMD)
* Part 38 Writing a software device driver
@High-End Če boš spet zbral članke v .PDF obliko, se priporočam za kopijo.
Aleš
Hi-End Član
Pridružen-a: Sre 25 Feb 2004 11:51 Prispevkov: 284 Aktiv.: 1.15 Kraj: Višnja Gora
Objavljeno: Čet Avg 30, 2007 8:44 am Naslov sporočila: |
Super! Tole je nekaj zame. Na mizi me čaka Virtex4, pa niti ne vem kje se zadeve lotiti. Če bo čas bom morda res naredil pdf z vsemi članki, kdaj pa bo to pa še ne vem, morda že danes.
_________________ Music is a part of my life, DIY is my life ! |
Auslander Član
Pridružen-a: Tor 08 Mar 2005 9:53 Prispevkov: 43 Aktiv.: 0.17
Objavljeno: Čet Avg 30, 2007 9:44 am Naslov sporočila: |
če se bo delal članek v *.pdf se priporočam tudi jaz
vsega še niem prebral naslov in uvod je obetaven...
mile Član
Pridružen-a: Čet 16 Mar 2006 12:14 Prispevkov: 70 Aktiv.: 0.29 Kraj: Volarje
Objavljeno: Sre Okt 17, 2007 9:29 pm Naslov sporočila: |
Že kar nekaj časa je mimo od zadnjega oglašanja; je mogoče že nastala skupna .pdf datoteka?
Se priporočam...
. Član
Pridružen-a: Ned 19 Sep 2004 22:04 Prispevkov: 16777193 Aktiv.: 67896.20
Objavljeno: Čet Okt 18, 2007 2:00 am Naslov sporočila: |
| Brisana vsebina odstranjenega uporabnika.
Silica FAE Član
Pridružen-a: Pet 01 Sep 2006 13:57 Prispevkov: 33 Aktiv.: 0.14 Kraj: Ljubljana (Dunajska), NM
. Član
Objavljeno: Čet Okt 18, 2007 11:36 am Naslov sporočila: |
| Opis: |
 Download |
| Ime datoteke: |
uClinux_MicroBlaze_Starter_Kit_1_00.pdf |
| Velikost datoteke: |
3.93 MB |
| Downloadano: |
33 krat |
