Prekinitve PIC12f683
Objavi novo temo   Odgovori na to temo   Printer-friendly version    www.elektronik.si Seznam forumov -> Osnove programiranja PIC-a v Assembler-ju
mucek4
Prispevkov: 2952
Aktiv.: 12.46
PrispevekObjavljeno: Pet Nov 02, 2007 10:35 am    Naslov sporočila:  Prekinitve PIC12f683 Odgovori s citatom
Prebrskal sem že forum, vendar nisem zasledil podatka.
Imam dokaj velik program pisan v ASM-ju. V simulatorju dela, na HW-ju pa noče skočiti v prekinitev.
Koda je sledeča, kaj bi bilo lahko narobe?
Koda:
   org 0x00
   goto MAIN
   org 0x05
   movwf WTMP                  ; Save W and status
   swapf STATUS,W               ;
   movwf STMP                  ;
   clrf STATUS                  ; Clear status
   movlw AND_LED               ; XOR LED
   xorwf GPIO, f               ;
END_INT
   swapf STMP,w               ;restore W and status
   movwf STATUS               ;
   swapf WTMP,f               ;
   swapf WTMP,w               ;
   retfie
   ; //interupt
MAIN
   BANK1
   movlw b'01100000'            ;
   movwf OSCCON               ;
   BANK0                     ; Inicialization
   clrw                     ; clear w
   addlw 0                     ; clear Carry
   movlw b'00000111'            ; disable comparator module
   movwf CMCON0               ; to enable digital I/O
   clrf GPIO                  ; Clear all ports
   BANK1
   movlw b'00100100'            ; GP5 & GP2 input
   movwf TRISIO               ;
   clrf ANSEL                  ;
   BANK0
   bsf LED                     ; Light up led
   BANK1
   movlw b'10000000'            ; enable timer0
   movwf OPTION_REG
   BANK0
   movlw b'00110001'            ; enable timer1
   movwf T1CON                  ;
   movlw b'01111110'            ; enable timer2
   movwf T2CON                  ;
   clrf TMR0                  ; clear TMR0
   clrf TMR2                  ; clear TMR0
   bsf INTCON, PEIE            ; enable peripheral interupt
   bsf INTCON, GPIE            ; enable interrupt on change
   bsf INTCON, T0IE            ; enable timer0 interrupt
   BANK1
   bsf IOC, IOC5               ; enable interrupt on pin change
   bsf PIE1, TMR1IE            ; enable timer1 interupt bit
   BANK0
   bsf INTCON, GIE               ; enable global interupt
   clrf FLAGS                  ; clear flags
   bsf COMMERROR               ; set communication error
   movlw .16
   movwf KEYTIMER               ; set keytimer to defalut
   BANK1
   clrf EEADR                  ; clear eeprom address
   bsf EECON1, RD               ; read position 0
   movfw EEDAT                  ; read address
   BANK0
   movwf KEY_ADDRESS            ;
MAIN_LOOP
   btfsc KEYVALID               ; if key is pressed long enough
   call KEYPRESSED               ; call subroutine
   btfsc COMMERROR               ; if not commerror
   goto MAIN_NEXT               ;
   btfsc COMMRESET               ; and commreset is set
   call COMM_START               ; call communication start!
MAIN_NEXT
   goto MAIN_LOOP
Upam, da je razumljivo napisano.
bungee
Prispevkov: 1479
Aktiv.: 6.24
PrispevekObjavljeno: Pet Nov 02, 2007 10:56 am    Naslov sporočila:   Odgovori s citatom
Kako veš, da ne skoči v prekinitev? In ali imaš definirane nivoje na vhodnih pinih, kjer prožiš interrupt?
Na oko koda izgleda OK.
Sokrat
Prispevkov: 5584
Aktiv.: 23.56
Zakaj pa org 0x05 ?!?!?!
mucek4
Prispevkov: 2952
Aktiv.: 12.46
PrispevekObjavljeno: Pet Nov 02, 2007 11:03 am    Naslov sporočila:   Odgovori s citatom
Sokrat je napisal/a:
Hm. Dobro vprašanje. Zakaj simulator dela dobro. Hw je pa vedno v W naložil 0xff.
Vem da ne skoči, ker gledam signale LED na osciloskopu. V prekinitev zdaj skoči, ko sem odstranil linker skripto. Ne vem zakaj je sploh prišla noter.
Sokrat
Prispevkov: 5584
Aktiv.: 23.56
PrispevekObjavljeno: Pet Nov 02, 2007 11:52 am    Naslov sporočila:   Odgovori s citatom
Saj addlw 0xff ni nelegalen ukaz, samo nesmiseln je, ker spremeni zastavice in vrednost v W za 1 (ce je bil prej flash pobrisan seveda, sicer je lahko naredil MCU kaj drugega).
Res bizarno, da niso pri Microchipu dolocili pobrisane lokacije kot NOP ... najbrz je to poenostavilo ukazni dekoder.
Objavi novo temo   Odgovori na to temo   Printer-friendly version    www.elektronik.si Seznam forumov -> Osnove programiranja PIC-a v Assembler-ju Časovni pas GMT + 2 uri, srednjeevropski - poletni čas
