Dolžina USB kabla
Prispevkov: 16777193
Aktiv.: 70786.03
PrispevekObjavljeno: Sre Sep 06, 2006 1:50 pm    Naslov sporočila:  Dolžina USB kabla Odgovori s citatom
jur
Prispevkov: 5142
Aktiv.: 21.70
PrispevekObjavljeno: Sre Sep 06, 2006 2:00 pm    Naslov sporočila:   Odgovori s citatom
http://www.usb.org/developers/usbfaq/#cab1
1. Why are there cable length limits, and what are they?
A: The cable length was limited by a cable delay spec of 26ns to allow for reflections to settle at the transmitter before the next bit was sent. Since USB uses source termination and voltage-mode drivers, this has to be the case, otherwise reflections can pile up and blow the driver. This does not mean the line voltage has fully settled by the end of the bit; with worst-case undertermination. However, there's been enough damping by the end of the bit that the reflection amplitude has been reduced to manageable levels. The low speed cable length was limited to 18ns to keep transmission line effects from impacting low speed signals.
2. I want to build a cable longer than 5 meters, why won't this work?
A: Even if you violated the spec, it literally wouldn't get you very far. Assuming worst-case delay times, a full speed device at the bottom of 5 hubs and cables has a timeout margin of 280ps. Reducing this margin to 0ps would only give you an extra 5cm, which is hardly worth the trouble.
Glitch
Pridružen-a: Pet 07 Apr 2006 11:40
Prispevkov: 1477
Aktiv.: 6.32
PrispevekObjavljeno: Sre Sep 06, 2006 2:18 pm    Naslov sporočila:   Odgovori s citatom
Za foro (ker sem vedel kaj bo) sem poskusal podaljsati USB kabel. Uporabil sem dva USB kabla (AA in AB). Jasno, naprava ni delala.
jur
Prispevkov: 5142
Aktiv.: 21.70
PrispevekObjavljeno: Sre Sep 06, 2006 3:00 pm    Naslov sporočila:   Odgovori s citatom
To omejitev dolžine so naredili zanalašč, da bi lahko prodajali USB hube.
mucek4
Prispevkov: 2952
Aktiv.: 12.46
PrispevekObjavljeno: Sre Sep 06, 2006 3:07 pm    Naslov sporočila:   Odgovori s citatom
Nekje "neuradni" podatki navajajo 10 metrov. Največ kar sem dosedaj rabil pa je bil 5 meterski podaljšek in 3 metre kabel. Stvar dela.
robert
Prispevkov: 1905
Aktiv.: 8.04
Kraj: Tolmin
PrispevekObjavljeno: Sre Sep 06, 2006 5:48 pm    Naslov sporočila:   Odgovori s citatom
Meni je Wlan USB kljucek Canyon delal na 2 x 5m + 2m "zelo kvalitetnega" kitajskega kabla-beri najcenejsega kar sem dobil Very Happy
Moram pa omeniti,da je slo za USB 1.1
LP Robert
trobida
Prispevkov: 1250
Aktiv.: 5.42
PrispevekObjavljeno: Sre Sep 06, 2006 6:40 pm    Naslov sporočila:   Odgovori s citatom
Robert lahko mogoče malo napišeš kakšna je bila hitrost prenosa podatkov pri taki dolžini kabla?
Tomaž, S57KO
Prispevkov: 5530
Aktiv.: 24.05
PrispevekObjavljeno: Sre Sep 06, 2006 6:59 pm    Naslov sporočila:   Odgovori s citatom
Jaz sem imel priklopljen printer na original narejenem 15m kablu (Manhattan), delalo bp.
LP, Grega
TOTAL
Pridružen-a: Sre 25 Jan 2006 9:18
Prispevkov: 109
Aktiv.: 0.46
PrispevekObjavljeno: Sre Sep 06, 2006 7:41 pm    Naslov sporočila:   Odgovori s citatom
Meni dela printer USB2.0 na 10m+1m imel sem probleme pri inštalaciji, ker mi ni zaznalo printerja sam, ko sem to zrihtal na krajšem delu in nato ustavi še 10m mi dela brez problema.
robert
Prispevkov: 1905
Aktiv.: 8.04
Kraj: Tolmin
PrispevekObjavljeno: Sre Sep 06, 2006 9:27 pm    Naslov sporočila:   Odgovori s citatom
trobida je napisal/a:
Uporabljal sem ga samo za Netstumbler,ko sem skeniral okolico za odprte mreze.Na zalost je bilo vse dosegljivo zaklenjeno Evil or Very Mad
LP Robert
trobida
Prispevkov: 1250
Aktiv.: 5.42
PrispevekObjavljeno: Sre Sep 06, 2006 9:38 pm    Naslov sporočila:   Odgovori s citatom
Aha ni problema Robert. Ima mogoče kdo izkušnje s tem. Recimo imam 10m dolg USB kabel in preko njega na PC prenašam podatke. Se hitrost prenašanja podatkov kaj bistveno spremeni, kot če bi imel [slovenščina je zame španska vas] recimo dolg 1m?
Hvala!
Tomaž, S57KO
jur
Prispevkov: 5142
Aktiv.: 21.70
PrispevekObjavljeno: Čet Sep 07, 2006 10:30 am    Naslov sporočila:   Odgovori s citatom
Omejitve dolžine kablov niso povsem eksaktno določljive. Omejitev pove tisto dolžino, pri kateri mora katerikoli kabel tistega tipa za tisti namen še vedno stoprocentno delovati. Ker pa imajo različni kabli različne karakteristike (karkoli je že to), bo z nekim kablom stvar delovala tudi na večjo dolžino od dovoljene. Nedelovanje (slabo delovanje) se tudi ne začne na določenem metru naenkrat, ampak postopoma narašča. Z tem podobno narašča tudi število napak. Če je napak malo, niso opazne, vendar delovanje ni več zanesljivo, oziroma stabilno.
Za prenos podatkov je vsekakor boljši ethernet. Velika hitrost (10, 100 ali 1000 Mb/s) in dolgi kabli do 100 metrov.
frank
Pridružen-a: Pet 13 Okt 2006 0:52
Prispevkov: 46
Aktiv.: 0.20
PrispevekObjavljeno: Ned Nov 19, 2006 10:19 am    Naslov sporočila:   Odgovori s citatom
Dobijo se USB/Cat 5 vmesniki, ki podaljšajo USB povezave,
poceni verzije, ki se dobijo pri nas gredo nadalnjih 5-10 metrov,
sam pa imam varianto, ki gre 150m, a stane precej, preveč za hobi uporabo
imam tudi enega, ki prenaša tudi napajanje, na koncu pa ima tudi hub 1/5
na net-u se jih najde pod "USB extender"
