Oddaja slik iz ISS na radioamaterskih frekvencah
s56al
Prispevkov: 788
Aktiv.: 3.33
Kraj: JN66SI & JN76TM
PrispevekObjavljeno: Pet Avg 06, 2021 7:51 am    Naslov sporočila:  Oddaja slik iz ISS na radioamaterskih frekvencah Odgovori s citatom
Danes (petek) popoldne in jutri. Za sprejem ni treba neke posebne tehnike. Gre že z "RTL-SDR" USB ključkom in vsaj za silo spodobno anteno. Več v pripetem besedilu.
ZCZC AS09
QST de W1AW
Space Bulletin 009 ARLS009
From ARRL Headquarters
Newington, CT August 2, 2021
To all radio amateurs
SB SPACE ARL ARLS009
ARLS009 SSTV Transmissions Scheduled from ISS
Friday and Saturday, August 6 - 7, Russian cosmonauts onboard the
International Space Station (ISS) will transmit slow-scan television
(SSTV) images from the station on 145.800 MHz FM. They will use SSTV
mode PD-120. The transmissions are part of the Moscow Aviation
Institute SSTV experiment (MAI-75) and will be sent via RS0ISS, the
ham station in the Russian Zvezda (Service) module using a Kenwood
TM-D710 transceiver.
The announced schedule is August 6, 1050 - 1910 UTC and August 7,
0950 - 1555 UTC. Dates and times are subject to change. For stations
in the ISS footprint, the RS0ISS signal should be easy to copy on a
handheld transceiver and a quarter-wave whip. Use 25-kHz channel
spacing, if available. Free ISS software is available to download.
Pass predictions are available from AMSAT via,
https://www.amsat.org/track/ .
Representative images from prior ISS
SSTV events are available in the ARISS SSTV Gallery at,
https://www.spaceflightsoftware.com/ARISS_SSTV/index.php .
Aktiv.: 33.05
PrispevekObjavljeno: Pet Avg 06, 2021 9:52 am    Naslov sporočila:   Odgovori s citatom
OpenWebRX web-based SDR receiver S54MTB
Prispevkov: 3531
Aktiv.: 31.54
PrispevekObjavljeno: Pet Avg 06, 2021 10:51 am    Naslov sporočila:   Odgovori s citatom
Če bi kdo tole dekodiral sam s pomočjo mojega sprejemnika, si lahko namesti virtualni avdio kabel in "spelje" zvok iz spletnega brskalnika v enega od sstv dekoderjev, npr:
https://hamsoft.ca/pages/mmsstv.php
Tule je še nekaj napotkov za uporabo lastnega sdr ključka:
https://www.rtl-sdr.com/tag/sstv/
s56al
Prispevkov: 788
Aktiv.: 3.33
PrispevekObjavljeno: Pet Avg 06, 2021 3:56 pm    Naslov sporočila:   Odgovori s citatom
Prva slika (delna) je tu Smile. Žal se je ISS skril iz vidnega polja moje antene še preden je bila slika prenešena v celoti...
Oprema: Yagi 2m kratka 3el obrnjena "krnekam" + TS-2000 + USB "digimode" (homemade) vmesnik + MMSSTV @ PC.
Signala je, dokler traja, na pretek.
Sprejem SSTV z ISS (ARISS)
 Velikost datoteke:  615.53 KB
Nazadnje urejal/a s56al Sob Avg 07, 2021 7:38 am; skupaj popravljeno 1 krat
s55m
Prispevkov: 2696
Aktiv.: 12.00
Kraj: Plovdiv-Bolgarija
PrispevekObjavljeno: Sob Avg 07, 2021 7:13 am    Naslov sporočila:   Odgovori s citatom
Sandi, a jih prosimo, naj se peljejo malo bolj pocasi? Smile Lepa slikca!
s56al
Prispevkov: 788
Aktiv.: 3.33
PrispevekObjavljeno: Sob Avg 07, 2021 7:37 am    Naslov sporočila:   Odgovori s citatom
Adi hvala, poskusim danes še kako "uštopat" Smile! V Bcu gre sprejem velik del preleta bolj na odboje, tu v MB sem pa skrit na S strani Pohorja, tik pod hribom, spet manjka nekaj začetnih / ključnih minut...
ARISS SSTV
 Velikost datoteke:  114.58 KB
Diploma ARISS SSTV
 Velikost datoteke:  1.85 MB
s56al
Prispevkov: 788
Aktiv.: 3.33
PrispevekObjavljeno: Sob Avg 07, 2021 7:40 am    Naslov sporočila:   Odgovori s citatom
Pa diplomo so "odvrgli" kar med enim od preletov Wink!
https://www.inspace.club/
Prispevkov: 6733
Aktiv.: 28.41
PrispevekObjavljeno: Sob Avg 07, 2021 10:45 am    Naslov sporočila:   Odgovori s citatom
Lepe slikce si uspel ujet. Applause
