Pridružen-a: Pon 23 Avg 2004 16:16 Prispevkov: 16777190 Aktiv.: 70783.47
Objavljeno: Ned Feb 04, 2007 1:12 am Naslov sporočila: Modri laser, HD-DVD... |
NeoTO Član
Pridružen-a: Pon 28 Mar 2005 19:19 Prispevkov: 2752 Aktiv.: 11.61 Kraj: Trzic
Objavljeno: Ned Feb 04, 2007 1:21 am Naslov sporočila: |
Drugače pa za Blu-ray:
How fast can you read/write data on a Blu-ray disc?
According to the Blu-ray Disc specification, 1x speed is defined as 36Mbps. However, as BD-ROM movies will require a 54Mbps data transfer rate the minimum speed we're expecting to see is 2x (72Mbps). Blu-ray also has the potential for much higher speeds, as a result of the larger numerical aperture (NA) adopted by Blu-ray Disc. The large NA value effectively means that Blu-ray will require less recording power and lower disc rotation speed than DVD and HD-DVD to achieve the same data transfer rate. While the media itself limited the recording speed in the past, the only limiting factor for Blu-ray is the capacity of the hardware. If we assume a maximum disc rotation speed of 10,000 RPM, then 12x at the outer diameter should be possible (about 400Mbps). This is why the Blu-ray Disc Association (BDA) already has plans to raise the speed to 8x (288Mbps) or more in the future. |
_________________ Lp,
Matevž |
NeoTO Član
Glitch Član
Pridružen-a: Pet 07 Apr 2006 11:40 Prispevkov: 1477 Aktiv.: 6.32
Objavljeno: Ned Feb 04, 2007 2:12 am Naslov sporočila: Re: Modri laser, HD-DVD... |
MarE69 je napisal/a: |
A ni bolje, če imaš kar zunanji disk malih dimenzij, velike kapacitete, en hot-plug SATA (a to obstaja), pa še obstojnost podatkov je precej daljša od zapisljivih nosilcev?
Ze v osnovi si zgresil primerjavo, zato pa ne gre skupaj. CD, DVD in ostali podobni nosilci so pravzaprav namenjeni prenasanju podatkov naokoli in ne primarni non-stop uporabi, kot jo imajo trdi diski. |
Olaf Član
Pridružen-a: Tor 14 Nov 2006 20:09 Prispevkov: 127 Aktiv.: 0.56 Kraj: Ljubljana
Objavljeno: Ned Feb 04, 2007 3:50 pm Naslov sporočila: |
Glede na Neotov citat - je potem Blue-Ray tehnologija boljša oz. hitrejša od HD-DVD?
Priznam, da se še nisem poglobil v detalje obeh, saj jih zaenkrat še ne potrebujem. Sem pa predvideval, da je razlika bolj v smeri +R in -R. _________________ To mi deli! |
Sokrat Član
Objavljeno: Ned Feb 04, 2007 5:00 pm Naslov sporočila: |
Ne, ni tako podobno, kot sta bila -R in +R. Precej na to temo je napisano ravno v tekoci stevilki Monitorja, ce bi rad bral zbrano gradivo v slovenscini, sicer pa je ogromno informacij (v anglescini) v internetu. _________________ Ka ti bo pa torba ce si kupu kolo ? |
GJ Član
Pridružen-a: Čet 02 Nov 2006 15:51 Prispevkov: 946 Aktiv.: 4.17 Kraj: Ljubljana
Objavljeno: Ned Feb 04, 2007 8:04 pm Naslov sporočila: Re: Modri laser, HD-DVD... |
Mene nekaj zanima: kako hitro gre zapisovanje na te nove nosilce? Malo zgrešeno se mi zdi da se proizvajalci zapisljivih medijev in pogonov tako mučijo s čimvečjimi kapacitetami, če zadeva ni res hitra, oz. vsaj pol tako hitra kot so diski. |
Poglavitna je cena nosilca! En DVD nosilec stane še vedno nekaj 100 krat manj kot trdi disk. Torej, za prenos podatkov je DVD povsem zadovoljiv.
A ni bolje, če imaš kar zunanji disk malih dimenzij, velike kapacitete, en hot-plug SATA (a to obstaja)... |
Še bolje pa je optika..
LP GJ |
Pridružen-a: Ned 19 Sep 2004 22:04 Prispevkov: 16777193 Aktiv.: 70783.48
Objavljeno: Ned Feb 04, 2007 8:33 pm Naslov sporočila: Re: Modri laser, HD-DVD... |
