I/K: D-FF ali IC za ON/OFF
dumr666
Pridružen-a: Tor 31 Jan 2012 23:30
Prispevkov: 409
Aktiv.: 2.51
PrispevekObjavljeno: Čet Mar 31, 2016 1:04 pm    Naslov sporočila:  I/K: D-FF ali IC za ON/OFF Odgovori s citatom
Iščem IC s katerim lahko preklapljam med on-off z navadno tipko. Opcija je D-FF. Če se kateremu valja, se priporočam za odkup parih kosov.
Robots will steal your job. But that's OK.
Prispevkov: 5820
Aktiv.: 24.56
PrispevekObjavljeno: Čet Mar 31, 2016 1:48 pm    Naslov sporočila:   Odgovori s citatom
Ali je CD4013 ali 74HC74 OK?
Lahko pa tudi kaj drugega iz spodnje tabele. Vsi ICji so THT.
Koda:
1    CD4001     Quad NOR gate
2    CD4010     HEX Buffer/Converter
3    CD40106    HEX inverting Schmitt trigger
4    CD4013     Dual D-Type Flip-Flop
5    CD4017     Decade Counter/Divider wih 10 decoded output
6    CD4019     Quad And/Or Select Gate
7    CD4020     14 Stage Rripple-Carry Binary Counter
8    CD4021     8-Stage Static Shift Register
9    CD40257    Quad 2 Line to 1 Line Data Selector/Multiplexer
10   CD4035     4-Stage Parallel In/Parallel Out Shift Register
11   CD4040     12 Stage Rripple-Carry Binary Counter
12   CD4042     Quad Clocked D Latch
13   CD4043     Quad 3 State R/S Latches
14   CD4051     8 Channel multiplexer/demultiplexer
15   CD4060     14-Stage Ripple Carry Binary Counter
16   CD4072     Dual 4 input OR Gate
17   CD4076     4 Bit D-Type Registers
18   CD4081     Quad 2-Input AND Gate
19   CD4093     Quad 2-InputNAND Schmitt Trigger
20   CD4094     8-Stage Shift and Store Bus Register
21   CD4511     BCD to 7 Segment Latch Decoder Drivers
22   CD4514     4 to 16 Line Decoder
23   CD4517     Dual 64 Stage Static Shift Registers
24   CD4521     24 Stage Frequency Divider
25   CD4538     Dual Precision Monostable
26   SN7406     HEX Inverter Buffer/Drivers with Open Collector
27   SN7407     Hex Buffer/Drivers with Open Collector HV
28   SN74154    4 to 16 Line Decoder/Demultiplexer
29   SN74184    BCD to Binary Converters
30   SN74F241   Octal Buffer/Line Driver 3-state
31   SN74HC00   Quad 2-input NAND gate
32   SN74HC02   Quad 2-input NOR gate
33   SN74HC14   Hex inverting Schmitt trigger
34   SN74HC175  Quad D-type flip-flop with reset; positive-edge trigger
35   SN74HC373  Octal D-type transparent latch; 3-state
36   SN74HC74   Dual D-Type Flip-Flop
37   SN74LS138  Decoder/Demultiplexer
38   SN74LS164  8 bit Serial in Parallel out Shift Register
39   SN74LS92   Divide by 12 Counters
dumr666
Prispevkov: 409
Aktiv.: 2.51
PrispevekObjavljeno: Čet Mar 31, 2016 2:17 pm    Naslov sporočila:   Odgovori s citatom
in en in drug sta v redu Mr. Green . Kako se bova zmenila?
Prispevkov: 5820
Aktiv.: 24.56
PrispevekObjavljeno: Čet Mar 31, 2016 2:33 pm    Naslov sporočila:   Odgovori s citatom
Lahko prideš iskat, lahko ti pošljem..
