dumr666 Član
Pridružen-a: Tor 31 Jan 2012 23:30 Prispevkov: 409 Aktiv.: 2.51 Kraj: Ljubljana
Objavljeno: Čet Mar 31, 2016 1:04 pm Naslov sporočila: I/K: D-FF ali IC za ON/OFF |
Iščem IC s katerim lahko preklapljam med on-off z navadno tipko. Opcija je D-FF. Če se kateremu valja, se priporočam za odkup parih kosov. _________________ Robots will steal your job. But that's OK. |
Jaka57 Moderator
Objavljeno: Čet Mar 31, 2016 1:48 pm Naslov sporočila: |
Ali je CD4013 ali 74HC74 OK?
Lahko pa tudi kaj drugega iz spodnje tabele. Vsi ICji so THT.
Koda: |
1 CD4001 Quad NOR gate
2 CD4010 HEX Buffer/Converter
3 CD40106 HEX inverting Schmitt trigger
4 CD4013 Dual D-Type Flip-Flop
5 CD4017 Decade Counter/Divider wih 10 decoded output
6 CD4019 Quad And/Or Select Gate
7 CD4020 14 Stage Rripple-Carry Binary Counter
8 CD4021 8-Stage Static Shift Register
9 CD40257 Quad 2 Line to 1 Line Data Selector/Multiplexer
10 CD4035 4-Stage Parallel In/Parallel Out Shift Register
11 CD4040 12 Stage Rripple-Carry Binary Counter
12 CD4042 Quad Clocked D Latch
13 CD4043 Quad 3 State R/S Latches
14 CD4051 8 Channel multiplexer/demultiplexer
15 CD4060 14-Stage Ripple Carry Binary Counter
16 CD4072 Dual 4 input OR Gate
17 CD4076 4 Bit D-Type Registers
18 CD4081 Quad 2-Input AND Gate
19 CD4093 Quad 2-InputNAND Schmitt Trigger
20 CD4094 8-Stage Shift and Store Bus Register
21 CD4511 BCD to 7 Segment Latch Decoder Drivers
22 CD4514 4 to 16 Line Decoder
23 CD4517 Dual 64 Stage Static Shift Registers
24 CD4521 24 Stage Frequency Divider
25 CD4538 Dual Precision Monostable
26 SN7406 HEX Inverter Buffer/Drivers with Open Collector
27 SN7407 Hex Buffer/Drivers with Open Collector HV
28 SN74154 4 to 16 Line Decoder/Demultiplexer
29 SN74184 BCD to Binary Converters
30 SN74F241 Octal Buffer/Line Driver 3-state
31 SN74HC00 Quad 2-input NAND gate
32 SN74HC02 Quad 2-input NOR gate
33 SN74HC14 Hex inverting Schmitt trigger
34 SN74HC175 Quad D-type flip-flop with reset; positive-edge trigger
35 SN74HC373 Octal D-type transparent latch; 3-state
36 SN74HC74 Dual D-Type Flip-Flop
37 SN74LS138 Decoder/Demultiplexer
38 SN74LS164 8 bit Serial in Parallel out Shift Register
39 SN74LS92 Divide by 12 Counters
_________________ Lp, Jaka |
dumr666 Član
Objavljeno: Čet Mar 31, 2016 2:17 pm Naslov sporočila: |
in en in drug sta v redu . Kako se bova zmenila? _________________ Robots will steal your job. But that's OK. |
Jaka57 Moderator
Objavljeno: Čet Mar 31, 2016 2:33 pm Naslov sporočila: |
Lahko prideš iskat, lahko ti pošljem.. _________________ Lp, Jaka |
