rashoba Neznanec
Pridružen-a: Sre 09 Jun 2021 8:08 Prispevkov: 3 Aktiv.: 0.06 Kraj: Zvornik
Objavljeno: Sob Jun 12, 2021 10:20 pm Naslov sporočila: Convert Arduino PWM 5V to analog output 0-10V |
Hi,
I want to convert the Arduino PWM output that is in the range of 0 - 5V to an analog output in the range of 0-10V.
Circuit can be divided in two parts:
1) An RC filter to get an analog output from the PWM signal that Arduino outputs. I have read some information about this kind of filters and it's seems that there is a rule that establish the relation between the time constant of the RC filter and the period of the PWM signal: the RC time contant should be greater than the period. In my case the time constant is 100 times greater.
2) An operational amplifier with a gain of 2 to obtain the output in the range of 0-10V.
Thanks in advance. _________________ Bez potpisa
Nazadnje urejal/a rashoba Ned Jun 13, 2021 10:15 pm; skupaj popravljeno 2 krat |
rplink3r Član
Pridružen-a: Tor 06 Feb 2007 20:02 Prispevkov: 507 Aktiv.: 2.27 Kraj: Levec
mucek Član
Objavljeno: Ned Jun 13, 2021 2:37 pm Naslov sporočila: |
If using opamp, a rail-to-rail opamp MUST be used to get whole 0-10 V range (if you use only single power supply), otherwise you won't get whole range up to 0 V. _________________ ...lahko pa se tudi motim ... |
rashoba Neznanec
Objavljeno: Pet Jul 09, 2021 9:35 pm Naslov sporočila: |
Hvala vam _________________ Bez potpisa  |
rashoba Neznanec
Objavljeno: Sob Avg 14, 2021 9:50 pm Naslov sporočila: |
Hvala _________________ Bez potpisa  |
