Convert Arduino PWM 5V to analog output 0-10V
rashoba
Pridružen-a: Sre 09 Jun 2021 8:08
Prispevkov: 3
Aktiv.: 0.06
Kraj: Zvornik
PrispevekObjavljeno: Sob Jun 12, 2021 10:20 pm    Naslov sporočila:  Convert Arduino PWM 5V to analog output 0-10V Odgovori s citatom
Hi,
I want to convert the Arduino PWM output that is in the range of 0 - 5V to an analog output in the range of 0-10V.
Circuit can be divided in two parts:
1) An RC filter to get an analog output from the PWM signal that Arduino outputs. I have read some information about this kind of filters and it's seems that there is a rule that establish the relation between the time constant of the RC filter and the period of the PWM signal: the RC time contant should be greater than the period. In my case the time constant is 100 times greater.
2) An operational amplifier with a gain of 2 to obtain the output in the range of 0-10V.
Thanks in advance.
Bez potpisa Smile
Nazadnje urejal/a rashoba Ned Jun 13, 2021 10:15 pm; skupaj popravljeno 2 krat
rplink3r
Prispevkov: 507
Aktiv.: 2.27
Kraj: Levec
PrispevekObjavljeno: Sob Jun 12, 2021 10:29 pm    Naslov sporočila:   Odgovori s citatom
Tested working:
https://www.pcdimmer.de/index.php/hardware/dmx512-hardware/dmx512-0-10v-output
Prispevkov: 5530
Aktiv.: 24.05
PrispevekObjavljeno: Ned Jun 13, 2021 2:37 pm    Naslov sporočila:   Odgovori s citatom
If using opamp, a rail-to-rail opamp MUST be used to get whole 0-10 V range (if you use only single power supply), otherwise you won't get whole range up to 0 V.
...lahko pa se tudi motim ...
rashoba
Prispevkov: 3
Aktiv.: 0.06
Kraj: Zvornik
PrispevekObjavljeno: Pet Jul 09, 2021 9:35 pm    Naslov sporočila:   Odgovori s citatom
Hvala vam
Bez potpisa Smile
rashoba
Prispevkov: 3
Aktiv.: 0.06
Kraj: Zvornik
PrispevekObjavljeno: Sob Avg 14, 2021 9:50 pm    Naslov sporočila:   Odgovori s citatom
rplink3r je napisal/a:
Tested working:
Hvala
Bez potpisa Smile
