Konica spajkalnika
Pojdi na stran Prejšnja  1, 2, 3, 4, 5
Aktiv.: 33.05
PrispevekObjavljeno: Sob Sep 04, 2021 12:12 pm    Naslov sporočila:   Odgovori s citatom
Odgovor sem ti našel tukaj.
However, if you ever happen to have poor quality tips or tips that have weared out, you can use a file to reshape them. The downside is that as the copper corrodes, you'll usually have to repeat this every 5-10 times you use it. Eventually the tip will have been filed so short that it is no longer usable.
ginger
Pridružen-a: Sob 21 Avg 2021 7:21
Prispevkov: 33
Aktiv.: 0.71
Kraj: Novo mesto
PrispevekObjavljeno: Ned Sep 05, 2021 10:27 am    Naslov sporočila:   Odgovori s citatom
Ta je za stran...
prilagam sliko, škoda, da nisem prej slikala, preden sem odščipnila del.
 Velikost datoteke:  1.25 MB
I make pretty things
Stran 5 od 5
